ArcGIS Viewer 3.2 for Silverlight released!
8379
12
12-06-2013 04:04 PM
RichZwaap
Version 3.2 of the ArcGIS Viewer for Silverlight is now available for download.  This release includes:
  • A new Query Layer tool that allows application designers to interactively define complex queries, while showing end-users a simple dialog consisting of labels, textboxes, and drop-down menus for inputting query values
  • Support for URL parameters to allow users to specify initialization parameters such as extent, scale, web map, and place search by including them in the query string of a Viewer application�??s URL
  • Pop-Up enhancements to provide improved appearance, performance, and the ability to open pop-ups by tapping features on the map
  • Support for using secure services that are federated with ArcGIS for Portal as well as connecting to ArcGIS for Portal instances that implement public-key infrastructure (PKI) or Integrated Windows Authentication (IWA) security
  • Developer enhancements to allow programmatic manipulation of window position and deferral of Viewer initialization
  • Integration with Visual Studio 2013
  • Windows 8.1, Windows Server 2012, and Windows Server 2012 R2 support
For more information about the release, check out the what's new help topic.  To download, go to the ArcGIS Viewer for Silverlight Resource Center.
If you have questions or feedback, please feel free to post here on the forum.
-The ArcGIS Silverlight Development Team
TimDonoyou
Hi Doug,
Yes I uninstalled 3.2 via control panel / add remove programs and then re-installed 3.1 from downloaded exe
Just to be on the safe side I made copies of the files and folders which are affected by the install - Apps, Builder, the xml files, etc
Once the 3.1 install has completed you can then rename them back to their original names and replace/merge the newly created folders as required...
Hope this helps - let us know if there is anything else.
Cheers
Tim
GilbertLasnier
I run the install to upgrade 3.1 to 3.2 its seam everything go well. But the only thing why I make the update is the define complex queries and I dont have, the Query Layers stay the same that 3.1 , I reload from the setting add tool, where I can have that new Query Layer tool to over kill my older one, or what is the way to correcte that installation...
Also the module go to coordinates IS NOT SUPORTED IN 3.2, I hope somebody will make the update..
Many thanks to all of you...Its a great interface...
GilbertLasnier
Sory its working you just select add new an you put an numeric value..but i need . go to coordinates
