WMS layer - visiblelayers with space character in name
1910
03-19-2013 05:29 AM
AlexandreLavoie
Hi!
I'm trying to use a wms layer as basemap in my Flexviewer 3.1 project.
Everything works great when my layer name has no space character.
As soon there's a space in only one name, wms service doesn't work anymore.
<layer type="wms" label="SCO wms" imageformat="jpg"
      skipgetcapabilities="true"
      visiblelayers="Maurice,CMQ,CMM,Centre du Quebec"
      version="1.1.1"
      url="http://xx.xx.xxx.xxxx/lizardtech/iserv/ows?" visible="true"/>
I've tried to replace space character with %20, _, %. no result...
I've tried to use the ids visiblelayers="1" no result...
Alex
RobertScheitlin__GISP
Alex,
   Use ArcCatalog to see exactly what you have to use for the visiblelayers Ids. Using the url you provided:
http://webservices.nationalatlas.gov/wms/transportation? I added it as a WMS Server and then double clicked on the lay I wanted to get the name for and this is what I see:
[ATTACH=CONFIG]22748[/ATTACH]
Don't forget to click the Mark as answer check on this post and to click the top arrow (promote).
Follow these steps as shown in the below graphic:
AlexandreLavoie
I've try other things...
<layer url="http://webservices.nationalatlas.gov/wms/transportation?" label="nationalatlas"
visible="true" type="wms"
visiblelayers="Transportation - Airports"
version="1.3.0"
skipgetcapabilities="true"/>
This is the layer's name i've got in ArcCatalog.
And this doesn't work!
It works with
visiblelayers="airports"
version="1.3.0"
Looks like an alias name
Alex Lavoie
Quebec city
Alex,
AlexandreLavoie
Thank you!
Works fine now.
Alex Lavoie
