WidgetManager Error #2124
14791
35
01-09-2012 07:23 AM
JustinGleeson
I have deployed a ThematicQueryWidget in my application. This works well but I always get a WidgetManager Error #2124 when I open the mapping viewer (see attached). This does not seems to stop the widget from working though. Any idea what causes this?
Code in main config
<widget label="Accessibility Maps" width="300" height="500"
                preload="open"
                left="95" top="50"
                icon="AccessMap_WidgetsPopUpsETC/assets/AccessMapTMW.png"
                config="AccessMap_WidgetsPopUpsETC/ThematicQueryWidgetAccessMap.xml"
                url="AccessMap_WidgetsPopUpsETC/widgets/Thematic Query Widget/ThematicQueryWidget.swf"/>
Code in ThematicQueryWidgetAccessMap.xml
<?xml version="1.0" ?>
<configuration>
    <!-- labelref should match the label of the operational layer's label in main config. -->
    <theme labelref="Train Stations" >
<query legendurl="AccessMap_WidgetsPopUpsETC/assets/AccessMap_National.png" >
       </query>
    </theme>
</configuration>
thanks
Justin
JustinGleeson
Justin,
   Have you double checked the paths then? Is this the right path and is there actually a AccessMapTMW.png in that folder?
Yes, this is all correct
What about the swf did you add the ThematicQueryWidget to your projects modules list and is it in that exact folder?
No sure what you mean about the project modules Robert. The ThematicQueryWidget.swf is in the correct folder as per the code.
Justin
RobertScheitlin__GISP
Justin,
   Are you using the compiled or uncompiled version of the Viewer?
JustinGleeson
Justin,
Robert,
I'm learning as I go along here. According to the 'readme' I'm using the compiled version of the ArcGIS Viewer for Flex 2.5
Justin,
   OK,  forget the modules thin that doesn't apply to you
things that look unusual in this XML:
<widget label="Accessibility Maps" width="330" height="500"
            preload="open" left="95" top="50"
            url="AccessMap_WidgetsPopUpsETC/widgets/ThematicQueryWidget/ThematicQueryWidget.swf" />
  • Most of your widgets paths start with widgets and not AccessMap_WidgetsPopUpsETC/widgets
  • mostly the widgets xml configuration file is in the same folder as the actual widget swf file
  • most of the time  the icon used is in the assets/images folder
So what about trying this:
             icon="assets/images/AccessMapTMW.png"
             config="widgets/ThematicQueryWidget/ThematicQueryWidgetAccessMap.xml"
             url="widgets/ThematicQueryWidget/ThematicQueryWidget.swf" />
JustinGleeson
Justin,
Robert,
The problem is still there. I think the main config is correct and work properly. The issue must be to do with either the ThematicQueryWidgetAccessMap.xml or the ThematicQueryWidget.swf. I don't have access to the code that creates the .swf, so either this is not working properly or it's with the ThematicQueryWidgetAccessMap.xml. The code is below - I don't think I'm missing anything though and everything displays corretly.
<configuration>
    <theme labelref="Gateways" >
 <query layer="1" legendurl="AccessMap_WidgetsPopUpsETC/assets/AccessMap_National.png" >
       </query>
    </theme>
  <theme labelref="Gateways and Hubs" >
       </query>
    </theme>
  <theme labelref="Settlements > 50,000" >
       </query>
    </theme>
  <theme labelref="Settlements > 20,000" >
       </query>
    </theme>
  <theme labelref="Settlements > 10,000" >
       </query>
    </theme>
  <theme labelref="Settlements > 5,000" >
       </query>
    </theme>
  <theme labelref="Settlements > 1,500" >
       </query>
    </theme>
  <theme labelref="Primary Schools" >
       </query>
    </theme>
  <theme labelref="Secondary Schools" >
       </query>
    </theme>
   <theme labelref="Main Internationl Airports" >
       </query>
    </theme>
   <theme labelref="Main Airports" >
       </query>
    </theme>
       </query>
    </theme>
   <theme labelref="Full Emergency Hospital (24hr)" >
       </query>
    </theme>
   <theme labelref="Partial Emergency Hospital" >
       </query>
    </theme>
   <theme labelref="GP Surgery" >
       </query>
    </theme>
   <theme labelref="Dentists" >
       </query>
    </theme>
 <theme labelref="Pharmacies" >
       </query>
    </theme>
 <theme labelref="Fire Stations" >
       </query>
    </theme>
 <theme labelref="Garda or PSNI Stations" >
       </query>
    </theme>
</configuration>
Justin,
   So where are your listfields? In the original ThematicQueryWidget.xml each query has listfields:
<configuration>
    <info>widgets/Samples/ThematicQuery/InfoColumnChartWidget.swf</info>
    <theme labelref="Unemployment" >
       <query layer="4" minscale="0" maxscale="25000001" legendurl="assets/images/Legend_unemp.png" > <!-- layer 4 is a state layer -->
           <listfields>
                <field name="NAME" alias="State" />
                <field name="UNEMPRT_CY" alias="2009 Unemployment (%)" />
                <field name="UNEMPRT_08" alias="2008 Unemployment (%)" />
                <field name="RATE_UNEMP" alias="Unemployment Change (%)" />
                <field name="TOTPOP_CY" alias="2009 Total Population" />
           </listfields>
           <columnchartfields>
                <field name="UNEMPRT_08" alias="2008" />
                <field name="UNEMPRT_CY" alias="2009" />
           </columnchartfields>
       </query>
Maybe try trimming down your queries untill you get it working correctly.
JustinGleeson
Robert,
problem solved! The Thematic Query Widget required the following code at the start
<configuration>
I didn't think I'd need this as I was not using the listfields or columnchartfields
thanks for your help again.
Justin
Justin,
    Glad you got it worked out. Please mark this post as answered by click on the check under this image: and promote by clicking on the upper arrow on any posts that helped you.
JORGELAGOS2
I need to create an option for the users to click on 5 hyperlinks to open some html pages. So I created an icon named Downloader.png. When I click on it I see my five options below. Then I tried to click in the html links below but I got WidgetManager Error #2124. Do you think is possible to feed the url with an html? Thanks in advance
Jorge Lagos
GIS Specialist
        <widgetgroup label="Downloads" icon="assets/images/Downloader.png">
<widget label="Property Sketches" left="50" top="50" icon="assets/images/Downloader.png" url="http://gis.trow.com/keystone_xl_steele_city_land/property_sketches/"/>
            <widget label="Pipe Yards" left="100" top="50" icon="assets/images/Downloader.png" url="http://gis.trow.com/keystone_xl_steele_city_land/Land_PY/"/>
            <widget label="Contractor Yards" left="150" top="50" icon="assets/images/Downloader.png"  url="http://gis.trow.com/keystone_xl_steele_city_land/Land_CY/"/>
            <widget label="Contractor Camps" left="200" top="50" icon="assets/images/Downloader.png" url="http://gis.trow.com/keystone_xl_steele_city_land/Land_CC/"/>
            <widget label="Route Variations" left="250" top="50" icon="assets/images/Downloader.png"  url="http://gis.trow.com/keystone_xl_steele_city_land/Route_Variations/"/>
        </widgetgroup>
Jorge,
  Nope, you can just feed it any url like that as the url that is provided is used by the widget manager to attempt to load an actual widget.
You need to look at the Link Widget I created just for what you are trying to do.
http://www.arcgis.com/home/item.html?id=5e4717fe1bb247f89b9092308e569c30
