Widget icons
772
08-11-2011 10:34 AM
CurtWalker
I have replaced all the stock widget icons with custom ones.  They look great along the header bar in Flex Viewer, but I noticed when I click one to open a wdiget the duplicate icon that appears in the upper left corner of the wdiget window is distorted.  I think it is actually a slightly enlarged version of the image that is used along the header bar.
Does anyone know which file in the Flex Viewer source I can edit so this doesn't happen?  I've had good luck so far editing the source.  For example I allowed for the max width of the logo to increase beyond the default of 80 pixels and I also increased the height of the header widget icons.
Now I just need to find the right file where I can change the settings on the widget icon that appears in the upper left corner of the widget winodw.
Thanks for your help.
RobertScheitlin__GISP
Curt,
   The widgets appearance which includes the icon size is controller in the FlexViewer2.4\src\com\esri\viewer\skins\WidgetTemplateSkin.mxml
CurtWalker
Thanks Robert that did the trick.
