Why does my layer not create a pop up?
3440
11
08-27-2014 09:25 AM
JoshWhite
Honored Contributor
I was attempting to just do a simple popup for a layer in my webmap.  I wanted to point out that it is time aware and the time widget is enabled if that has anything to do with it.  I tried a point feature popup for testing and it worked fine and so I tried a line feature and it also worked.  The only difference appears to be the fact that it is time aware and the time widget is enabled.
Josh White, AICP
Principal Planner
City of Arkansas City
JoshWhite
Honored Contributor
Ah Crap!  I hate the reserved word list.  I don't understand what it would be used for that needs to be reserved.  I will create a new field called Year_ and just but a better alias on it.  I appreciate your help on this Robert!
Josh White, AICP
Principal Planner
JoshWhite
Honored Contributor
I changed the original title to reflect the fact that this issue had nothing to do with it being Time aware but was instead a reserved field name being used.
Josh White, AICP
Principal Planner
