Why am I getting a Security error in the preview tab of the Application Builder 3.6?
2902
10-24-2014 06:51 AM
JoshWhite
Honored Contributor
I keep getting an error when viewing the preview in the Application Builder 3.6.
The error states:
LayerName layer failed to load: Fault code: Channel.Security.Error
Fault info: Security error accessing url
Fault details: Destination: DefaultHTTP
My layers are all pointed to an external ip address and going to the a browser and pulling up the application using the external ip, everything works fine.  If you use the internal address http://servername/flexviewers/appname you also get the security error.  None of my existing layers have any security enabled on them that I am aware of, what could be causing this?
Josh White, AICP
Principal Planner
City of Arkansas City
Tags (1)
RobertScheitlin__GISP
Josh,
   Do you have a crossdomain.xml file setup on your web server and ArcGIS Server if they are not on the same machine?
Josh,
JoshWhite
Honored Contributor
They are on the same machine.  There is a crossdomain file that perhaps is not configured correctly.  In fact I found a default crossdomain file and saved it, and now the problem is gone.
Josh White, AICP
Principal Planner
