Use Field Alias for Info Popup Widget
1025
04-05-2011 04:34 AM
JakeSkinner
Esri Esteemed Contributor
Hello,
I am using the sample viewer for Flex, version 2.2.  I am trying to configure the Info Popup Widget to use the field alias rather than the field name.  Is there a way to do this w/o having to change the code using Flash Builder?  I am hoping to just edit the XML file for this change.
Thanks!
JakeSkinner
I found you can use field alias' with the following widget:
http://www.arcgis.com/home/item.html?id=4ec33120c9ea4d019fddf722fc34ea3c
AlexSanders
Jake,
Did you change the field alias in your .msd before you published it to a service?
