Type Coercion Failed Error of the same Class
1235
02-25-2011 08:49 AM
DeonaEvans
Has anyone ever received this error:
TypeError:  Error #1034:  Type Coercion failed.....
The error goes on to list the two classes that it cannot convert between and they're the same class.  I've read that this has something to do with the swf loader and the application domain.  So my question is, how does this plan into the FlexViewer?  There is a message being sent from the main app to another module.  So how do I make sure this doesn't happen?
Any ideas?
DasaPaddock
DeonaEvans
That was the fix.  Thanks!
KyleTraff
My flex viewer 2.2 application currently contains a number of Widgets that are managed by the Widget Manager.
I tried to fix the issue you solved above by loading all widgets into the same application domain as the loader:
    wgtInfo.load(ApplicationDomain.currentDomain, null, null, moduleFactory);
I now get the following error whenever I attempt to load the Helper widget:
> TypeError: Error #1009: Cannot access a property or method of a null object reference.
Am I missing something?  Thanks in advance.
