Turn off Basemaps
1199
10-10-2012 12:57 PM
LeroyChristophersen
I have placed some basemaps on my maps as an option for the user, using MapSwitcher widget.  However, they cannot get the basemap to turn-off when they still want to look at the data, but not have the basemap display.  How can this be done?  I am using the compiled format.
AnthonyGiles
Honored Contributor
Leroy,
You could publish a mxd that just contains an empty feature class and then add this as another basemap giving it a name of "Turn off Base Map" or have a look at my base map style widget that allows you to change the apperance of  tiled map services:
http://www.arcgis.com/home/item.html?id=3d1ea673ad15413db81262a4e73184ac
If you can use the source code you could create a totally white filter
Regards
Anthony
