Trim Trailing space in popup maybe by using SQL in definitionexpression?
1228
09-28-2011 11:21 AM
CharlesHarris
I'm wondering if there is a way to trim the trailing whitespace for a field in a mapservice for use in a popup.  The example is shown below, I am displaying a service hosted by esri that displays health care facilities nationwide and I have formatted a popup to display the address by adding the fields in the appropriate order to the <![CDATA]/> tag.  However, the city field has several trailing spaces that I'd like to get rid of.  How can I do it?
I tried to use a definitionexpression with the SQL TRIM() function on the appropriate sublayer to no avail.  Can anyone point me in the right direction?
I'm including a screenshot of the example, the layer tag for the main config file and the popup.xml
layer tag
  <layer label="Nationwide Hospitals" type="dynamic" visible="true" alpha="1" visiblelayers="6,12,18"
   url="http://maps3.arcgisonline.com/ArcGIS/rest/services/A-16/HHS_IOM_Health_Resources/MapServer">
                <sublayer id="6" popupconfig="popups/popup_ESRI_WOL_HealthHomeServices.xml" definitionexpression="ARC_City = TRIM(BOTH ' ' FROM ARC_City)"/>
                <sublayer id="12" popupconfig="popups/popup_ESRI_WOL_HealthHomeServices.xml" definitionexpression="ARC_City = TRIM(BOTH ' ' FROM ARC_City)"/>
                <sublayer id="18" popupconfig="popups/popup_ESRI_WOL_HealthHomeServices.xml" definitionexpression="ARC_City = TRIM(BOTH ' ' FROM ARC_City)"/>
         </layer>
popup
<?xml version="1.0" ?>
<configuration>
    <title>Health Home Services:  {ProviderName}</title>
    <description>
 <![CDATA[Health Home Services Number:    {ProviderNum}<br>Address:    {ARC_Address}<br>                     {ARC_City}, {ARC_State} {ARC_Zip}<br>Phone Number:  {Telephone}<br>Date Certified:  {DateCertified}<br>Ownership:  {OwnershipType}]]>
     </description>
 <fields>
 </fields>
</configuration>
Jeremy
