TOC Widget - Layers expandable initially?
1536
07-26-2012 08:25 AM
ShaningYu
Honored Contributor
To make the layers expandable initially, in TOCWidget.xml I added
  <expandlayeritems>true</expandlayeritems>
But it still does not work.  Any idea you can share?  Thanks.
RobertScheitlin__GISP
Shaning,
   In the TOCWidget.xml there are these self explanatory tags:
    <tocsettings>         <expanded everything="false">false</expanded>         <collapselegends>true</collapselegends>         <disablezoomtomenuoption>true</disablezoomtomenuoption>     </tocsettings>
And if you need more details on what they do then see the ReadMe.txt
Shanning,
   I think you are confusing the TOC Widget (mine) and the LayerList widget or MapSwitherWidget (esri)... The configuration <expandlayeritems>true</expandlayeritems> is for the LayerListWidget or the MapSwitcherWidget.
ShaningYu
Honored Contributor
I know it is for the LayerlistWidget.  Does your TOCWidget have a similar property like that?  Thanks.
Shaning,
ShaningYu
Honored Contributor
Wonderful!!  Thanks.
