Time Widget does not work when Time Extent From Layer is selected.
762
01-03-2013 01:23 PM
JosephShanahan
I set up the ArcGIS Viewer for Flex. I added the Time widget.
When I set up the Time Extent to use the Time Extent from Layer it does not work.
However, if I select Specific times and set the Start time and End time  then it works correctly.
This suggests I have either not published the service correctly and there is a bug in the Widget.
Has anyone got it working correctly by selecting Time Extent from Layer.
Regards
Joseph Shanahan
ESRI Australia
