Tiled Map Service Style Widget
1256
04-19-2012 07:46 AM
AnthonyGiles
Honored Contributor
All,
I have just uploaded a simple widget for Flex Viewer 2.5 that allows the user to change the appearance of tiled map services, the primary use for myself was to allow the end user to change the base map to either gray scale or destaurated so that operational layers stand out easier.
Sample code compiled and uncompiled can be found here:
http://www.arcgis.com/home/item.html?id=3d1ea673ad15413db81262a4e73184ac
Regards
Anthony
AnthonyGiles
Honored Contributor
Thank you Robert Scheitlin for hosting sample for me, link above now changed
