Static Image widget
2213
7
05-09-2012 12:20 PM
EricStarn2
Hello,
I am looking for the best way to just display some text (info), maybe also an image, about some subject matter on my viewer. The information would be an explanation of what the data is presenting. I was thinking of using the static image widget so a user could just click it and see the info but I am not sure how to add text to the widget.
How can I do this or is there a better way to proceed in this?
Any help would be great
Eric
AnthonyGiles
Honored Contributor
Eric,
Don't forget to also mark the post as answered by clicking on the tick
Regards
Anthony
AnthonyGiles
Honored Contributor
Eric,
Have a look at this post it may be the solution you are after:
http://forums.arcgis.com/threads/56727-Moveable-Static-Image-Widget
Regards
Anthony
EricStarn2
Thanks but I can use little more help in the install of the widget.
I created a new widget named MoveableImage in the Widget folder and added the .xml and .mxml file and then compiled it to produce the .swf file.
I however am not sure where to use the flash file that was also in the downloaded file. So as you can guess it is not working.
Eric
AnthonyGiles
Honored Contributor
Eric,
I've not actually tried the widget but I guess the .swf file that was in the zip was a complied version of the widget as I cannot see any reference to it in the mxml.
Can you expand on why the widget is not working (i.e. any error messages you are getting)
Regards
Anthony
EricStarn2
My apologizes Anthony
I actually figured it out.
It was a problem in my config file
Typical user error
The widget looks good but is there a way to invert the order of the widget so it is image then text?
Thanks
Eric
AnthonyGiles
Honored Contributor
Eric,
Sure you can, If you can edit the source code swap the two lines below around from:
<s:Label id="imageText" text="{lbl}"  fontSize="20" />
<mx:Image id="img" source="{imgURL}" scaleX="{sclX}" scaleY="{sclY}"/>
to:
Please dont forget to mark the post as answered
Regards
Anthony
EricStarn2
Perfect
Thanks again
Eric
AnthonyGiles
Honored Contributor
Eric,
Regards
Anthony
