Spatial Query using FlexViewer
2928
05-18-2011 06:00 AM
HERSHSINGH
Hello,
Are any of you aware of any widgets that I can use to perform spatial queries for my flex applications?  I am trying to be able to have the user select a geographic area (polygon) and return the feature (points) that fall within it?
I looked through the widgets but did not see anything.  Would this require complex coding or can it be done by a novice like myself?
Thanks in advance for the help.  It is very much appreciated.
HERSHSINGH
Mmm.  I guess not.  This would be an extremely useful widget....(nudging all of you widget developers out there).
EmilioSolano
Hello,
I will suggest that you look into the Flex apps and widgets gallery for the eSearch widgets by rscheitlin, they do have an spatial search component and it is a very solid and flexible widget.
Emilio
DasaPaddock
The Search widget also allows the user to perform spatial searches:
http://help.arcgis.com/en/webapps/flexviewer/help/index.html#/Search_widget/01m300000023000000/
