Show scale with coordinates
9681
21
02-23-2011 03:19 PM
DanielOchoa
The coordinate widget shows lat/long mouseover coordinates in the map, but can anyone advise on how to display map scale alongside the coordinates? Take a look here:
http://top100projects.ca/map/
or see the screen shot, attached.
Simple adjustment to the coordinate widget? Thanks!
RobertScheitlin__GISP
Jamal,
   You can not use this code change if you are only using the ArcGIS Viewer Application Builder. When you use the App Builder or the compiled Flex Viewer you are ONLY configuring the application though XML changes. When people in these forums talk about code changes they are speaking of using the AGS Viewer for Flex source code and some Flex IDE, like Flash Builder.
Robert
JamalNUMAN
Legendary Contributor
Jamal,
Robert
Many thanks for the answer Robert.
Best
Jamal
Jamal Numan
