shape files with same projection but don't overlay
3692
9
08-09-2014 03:58 AM
Environgis
I have data of shape files (lakes of same area) from two different years...one file have UTM WGS1984 projection while other have WGS1984 Zone 43N,I have to overlay them for analysis but even after giving them same projection, it doesn't work.Any solution please?
DanPatterson_Retired
the first file has no zone designation.  I would check both files to see if they are indeed 43N...perhaps one is a GCS which means that it is not projected at all.
RobertScheitlin__GISP
Environ gis,
   Are you sure you are posting in the right space? Are you using my ArcGIS Viewer for Flex Shapefile widget? It may help to attach your shapefiles so we can look at their actual projection.
curtvprice
This may be a key here. Did you use the Define Projection tool? That is the wrong tool to use as it only changes the description of the xy values. You should use the Project tool if you intend to project the data from one coordinate system into another.
stefanstamenov
Project the layers again in one projection.
Environgis
i projected them in 43N and in UTM as well but it didn't work.
Assuming you are using ArcMap, go into ArcCatalog and copy and paste the coordinate system information.  One may be "defined" as UTM 43N but it may not be projected as such.  If they were properly defined and/or projected they would line up. The error lies with way this was done.
Environgis
Thank you Sir..   in Arc Catalog, files are projected much better as compared to arc map
Environgis
As I have to find out lakes of 2005 that are present in 2013, newly appeared and disappeared lakes... can you recommend which tool I should use? e.g intersect or ???
curtvprice
Union is probably the tool you want.
