Shaded relief
859
06-16-2014 11:36 PM
KumarNJ
I need to know the contents of following link by ESRI related to shaded relief map.
http://resources.arcgis.com/en/help/flex-viewer/live/index.html?config=config-all.xml
1. Is it 2D or 3D
2. Apart of hillshed DEM, other geographic information is in Toposheet raster or vector data?
My purpose is I need to publish similar type of service on our GIS portal n 2D environment using our Base maps(vector)
Regards,
Kumar NJ
AnthonyGiles
Honored Contributor
Kumar,
Are you talking about the topographic and terrain basemaps:
http://www.arcgis.com/home/item.html?id=c61ad8ab017d49e1a82f580ee1298931
http://www.arcgis.com/home/item.html?id=30e5fe3149c34df1ba922e6f5bbf808f
They are just cached services, so they will have been made by using various layers in arcmap then published to server and a cache created. The service is just flat images in .png format.
Regards
Anthony
