Search Widget+RPC Fault faultString error
2756
09-22-2014 08:56 PM
SaurabhGupta5
I have migrated the modified search widget to Flex 3.6 from 2.X and Arc GIS Server 10.2.2, but when I want to make a buffer it return this error:
[RPC Fault faultString="Invalid or missing input parameters." faultCode="400" faultDetail="the input is not a geographic or projected coordinate system"]
what is the reason of this error?
Below are the parameters passed:
bufferSR=0
unionResults=true
inSR=3414
geometries={"geometryType":"esriGeometryPolygon","geometries":[{"rings":[[[30803.602299999955,31489.83940000087],[30814.99679999928,31475.538000000655],[30809.764599999995,31474.956700000905],[30807.439199999117,31478.21230000071],[30803.36970000009,31483.328199999396],[30802.788299999662,31486.93270000072],[30803.602299999955,31489.83940000087]]]}]}
f=json
unit=9001
distances=500
XML is having below tag
<spatialreference>3414</spatialreference>
Please help
SaurabhGupta5
Hi Anthony,
Thanks for your quick reply but after drilling down onto issue, i have realized that if i change my spatialreference tag within xml to one shown below , its working
To
<spatialReference>3414</spatialReference>
Regards
Saurabh
AnthonyGiles
Honored Contributor
Not sure if this is the reason for your error but I seem to recall when I moved from a 9.3.1 server to a 10.1 server the REST inputs required for a buffer to run slightly changed and the output spatial reference had to be specified where it previously didn't.
try making sure your outSR is specified.
SaurabhGupta5
Hi Anthony,
To
Regards
Saurabh
