Search Widget Results in Attribute Table
933
07-15-2013 03:35 PM
by Anonymous User
Not applicable
Original User: mdmejac
Hi All,
I was wondering if there is a way to set aliases for the search widget results when they appear as an operational layer in the attribute table widget?  It appears that my searchwidget.xml is limiting the results to be just the fields that I have identified as well as setting the aliases (see atatched screenshots).  When it pulls the operational layer into the attribute table widget, it does not keep those aliases though.
Is there a way to add tags to the attributetablewidget.xml in order to set the aliases for the field names of the selected layers form the search widget, or do i need to go another route?
Any help, as always, is greatly appreciated.
Mike Mejac
ScottThomas1
I am having the exact same problem. Wondering if you found a solution.
