Search Widget Not Selecting Features
3018
6
09-28-2010 01:26 PM
EmilyLaMunyon
I am trying to modify the Search Widget that came with the Sample Flex Viewer 2.0, to search on my own layers. I think I am close, but I continue to get a message that reads: Features selected:0, this happens when I do a graphical as well as text search. My SearchWidget.xml is below. Is there something I am missing for this to work on my rest layers?
Thanks in advance:)
<?xml version="1.0" ?>
<configuration>
    <layers>
        <layer>
            <name>SLCo Trails</name>
            <url>http://gis.slco.org/wwwrest/services/Utah_Trails/Polygons2/MapServer/3></url>
            <expression>Name LIKE'%[value]%'</expression>
            <textsearchlabel>Search by Name:</textsearchlabel>
            <graphicalsearchlabel>Use one of the graphical search tools to select</graphicalsearchlabel>
            <titlefield>Name</titlefield>
            <linkfield></linkfield>
            <fields all="false">
                <field name="Name"/>
            </fields>
        </layer>
        </layers>
    <zoomscale>5000</zoomscale>
    <info>widgets/InfoTemplates/InfoPopupWidget.swf</info>
</configuration>
MehulChoksey
Try all caps for NAME instead of "Name" The field names are case sensitive.
<configuration>
<layers>
<layer>
<expression>NAME LIKE'%[value]%'</expression>
<titlefield>NAME</titlefield>
<field name="NAME"/>
</fields>
</layer>
</layers>
</configuration>
EmilyLaMunyon
Thanks Mehul,
I just tried that and it is still not woring. Do you think it has something to do with my layers?
DasaPaddock
Are you using Viewer version 2.0 beta or 2.1?
EmilyLaMunyon
I am using 2.1.
MehulChoksey
Removing extra > after /3 in the url below worked for me:
Tried searching for HOGLE ZOO and it returned result.
EmilyLaMunyon
That was it! I cannot believe I missed that, I will look more closely at my code from now on. Thanks for your time:D
