Robert's Identify Widget - Question on links support
1322
01-20-2012 08:04 AM
EricVenden
Robert,
I haven't looked at your Identify widget since you released the 2.5 version, but I am wondering if the current iteration (2.5.3) of the Identify widget could be configured to use a particular "locked in" URL (as is currently available in the 'iconprefix' tag) and then use the value of a particular field (that has been identified) from the layer to append to the end that URL (as is currently available in the 'iconfield' tag) and then use those values to build a clickable link.
Thanks for your time
Eric V
RobertScheitlin__GISP
Eric,
   Yep, you can in the latest version and you can also have multiple links now.
Don't forget to click the top arrow (promote) and to click the Mark as answer check as shown below:
Eric,
