Resizing of Widget Icon in Header.
3068
11-26-2012 02:27 AM
shabbirsiddiqui2
I am trying to decrease my widget Icon which appears on the header, I tried but not getting any idea ,can any one please suggest me how can i do it.
Thanks and Regards,
Shabbir
RobertScheitlin__GISP
Shabbir,
   Here is a link to where I cover how to change the icon sizes in the header:
http://forums.arcgis.com/threads/34685-Modify-Icon-SIZE-of-Widget-that-is-diaplayed-in-the-Header-Co...
Don't forget to click the Mark as answer check on this post and to click the top arrow (promote).
Follow these steps as shown in the below graphic:
BjornSvensson
Esri Alum
To make the icon look smaller, you can create an image with more transparent space around it.  Depending on your image program it might be called something like "Resize canvas" or "Image->Canvas size..." (the latter in http://pixlr.com/editor/).
While Robert's solution works, the above following suggestion doesn't require any code changes, only some image manipulation 🙂
shabbirsiddiqui2
Thanks for quick response .
