Reposition widgetcontainer
2498
12
01-27-2011 10:58 AM
BobCarberry
I created a custom search UI element widget which resides on the HeaderController.  It takes up a lot of space and doesn't leave much room for the widgetcontainer.  Does anyone know of an easy way to move the widgetcontainer from the HeaderController?  I wound like to move it below the HeaderController.  Another nice way I saw this issue being addressed was to place the widgetcontainer and other tools in a horizontal scroll like control.  Here is the link from Calhoun County, Alabama:  http://gis.calhouncounty.org/FlexView/Index.html  If anyone could give any pointers or steer me in the right direction, that would be great!
DasaPaddock
You can set left, right, top or bottom on the widgetcontainer. See:
http://help.arcgis.com/en/webapps/flexviewer/help/widgetcontainer_tag.htm
BobCarberry
Dasa,
Thanks for your reply, however I tried that and the widgetcontainer still does not reposition.  Is there something else I must do?  It seems that all the code that sets everything for the widgetcontainer is found within the HeaderControllerWidget.   Do I need to set something there as well?
RobertScheitlin__GISP
Bob,
  I will see if I can post some code for this might be next week though.
BobCarberry
Bob,
Thanks so much Robert!
Bob,
   Here is the source for a scrollable HeaderControlWidget
BobCarberry
As always, thanks you so much Robert!  I've integrated the new header and it works great!  I have 1 question for you however, I noticed on your site you have navigation tools integrated within the scroll bar as well. Are these widgets that were added to the widgetcontainer? I have a couple UI elements that I would like to add to this scroll bar as well.  Is this possible?
Bob,
   My sites navigation controls are custom nav widgets that I developed to go in the HeaderControlWidget.
I stripped a lot of different stuff out of the version I posted. I can't given away all my sites uniqueness!
BobCarberry
I completly understand!  I think I figured out a solution anyway.  Thanks you so much again!
LarryStout
Thanks, Robert.  I had taken a different approach to the widget icons.  I was grouping them as the Header Controller became smaller.  It worked, but I liked your idea better so I abandoned my code in favor of yours.
