QUESTION: Search Widget expression with UPPER
988
10-06-2010 06:55 AM
xanderm
In version 1.x I was able to run the search widget with UPPER as part of my expression (Oracle SDE all caps search)
<expression>PAR_OWN LIKE UPPER'%[value]%'</expression>
However, this statement does not return any results in 2.x. If I use the expression w/o UPPER and type my search string in all caps I get results.
<expression>PAR_OWN LIKE '%[value]%'</expression
BjornSvensson
Esri Alum
Did you forget the parentheses? The SQL function is UPPER().
<expression>PAR_OWN LIKE UPPER('%[value]%')</expression>
Or if your server has mixed casing content:
<expression>UPPER(PAR_OWN) LIKE UPPER('%[value]%')</expression>
xanderm
I did forget them() in my post but not in my source code.
I have tried both without luck:
And
A partial search string works but only if type the correct case in the search box.
