Question on widgte container
2865
10-03-2013 07:41 AM
MayJeff
When you try to change your screen size from full screen to smaller screen, widget container won't resize to fix into your current screen.  Did anyone has any ideas to make widget containers look better?  I saw this link http://resources.arcgis.com/en/help/flex-viewer/live/index.html?config=apps/config-search.xml but how do you show the arrow icon beside your widget?
Thanks.
RobertScheitlin__GISP
May Jeff,
    To put the widget container controls beside your widgets you just need to change the layout attribute of your widgetcontainer to vertical instead of horizontal.
May Jeff,
MayJeff
Thank you.
May Jeff,
   Dont forget to click on the check mark as well to indicate that this thread has been answered.
