Printing Widget Data
1372
11-17-2012 02:24 PM
Ronde_las_Alas
What is the best approach for printing data contained inside a widget? I am looking at the print widget, but I am under the impression it only prints maps and map data.
Ron
MLowry
Data inside a widget? Like search results in a table or what? Can you provide a use case?
Ronde_las_Alas
Yes. That is exactly what I am doing. I am currently testing out Flex's PrintDataGrid component, and it seems to be doing the trick. Do you have any other suggestions?
TomSchuller
Hy,
if you want to print out a widget content, you should take a look at this method:
  ImageSnapshot.captureImage(...
See also here:
  http://thunderheadxpler.blogspot.com/2008/11/saving-map-snapshot.html
  http://forums.arcgis.com/threads/5731-Include-Overview-Map-in-Snapshot-Image
Tom
