Print Widget
2147
10-10-2013 06:29 AM
ChadHall
Anyone else experiencing trouble with the print widget in Flex 3.1 this morning?  Any of my services fail when trying to print.  Below is the error I receive...
Error executing print task:
[RPC Fault faultString="HTTP request error" faultCode="Server.Error.Request" faultDetail="Error: [IOErrorEvent type="ioError" bubbles=false cancelable=false eventPhase=2 text="Error #2032"]. URL: http://sampleserver6.arcgisonline.com/ArcGIS/rest/services/Utilities/PrintingTools/GPServer/Export%2..."]
JanieGoddard
Hi Chad,
   All of my production Flex Viewers version 3.0 are blowing up when the users try to print. I get the Server.Error.Request error.
URL: http://sampleserver6.arcgisonline.com/ArcGIS/rest/services/Utilities/PrintingTools/GPServer/Export%2...Layout%5FTemplate=Letter%20ANSI%20A%20Landscape&f=json&Format=PDF&Web%5FMap%5Fas%5FJSON=%7B%22layoutOptions%22%3A%7B%22legendOptions%22% and etc.
I thought it was just us. Thanks for putting this out there.
Thanks, Janie
RobertScheitlin__GISP
Both of you should not be using esris sample server services if you have your own ArcGIS Server 10.x that has a print service running. Esri does not recommend the use of sample servers in a production environment.
