Print Widget - Final Output Scale Issues
1093
02-07-2014 04:19 AM
TimHohn
I've been having an issue with the Print Widget utilized by the Flexviewer 3.4 application.  The problem only occurs when utilizing a base layer from ArcGIS Online, and in our case we use the ESRI Imagery as the Default basemap.
The final print document (PDF) shows the Basemap extent correctly, the same as seen in my viewing window.  However, for some reason my operational layers do not appear in the PDF as they do in the viewing window.  They appear in the PDF at the next zoom extent, that is to say they appear to be "blown up" in relation to the extent of the Basemap Layer.  When the ArcGIS Online baselayers are turned off, or when utilizing our internal imagery services, the problem does not occur.  Any ideas?  Thanks!
