PopUp Window Larger
1444
07-22-2011 02:18 PM
JessicaYates
I am attempting to make the PopUp Window larger.  Right now it is cutting off my attributes names... So it ends up looking like this State N....    When it should say State Name.
Any suggestions!
Thanks!
MeganBirch
Did you ever get a response to this?  I'm encountering the same issue.
HERSHSINGH
same here.  I am hoping there is a fix for this coming soon.
PatrickMullen1
I don't believe there is a way to change it without modifying the source code.
Check out this link to add the pop up renderer skin and modify it.
http://forums.arcgis.com/threads/28601-Pop-Up-Spacing?highlight=popuprenderer
<s:SparkSkin ---- Width="270" change that to whatever makes the stuff fit. Also, you want to change labelWidth to fit in more characters.
