Popup not showing over my point file: displays elswhere in the world.
2182
10
08-24-2011 09:44 AM
dcopple
In Flex Viewer 4 - I have a dynamic layer that displays fine.  Have built a popup xml file for that layer.
I have other layers with the same spatial reference that display fine.
One difference I do see is that the HTML Popup Type on the other layers on the server are set to None.  And on the layer not working is set to AsHTMLText, could that be a problem?
Is there a way to specify where to make the popup show up in the application in the popup configuration file?  Any ideas would be appreciated
Don
dcopple
Ok, more interesting information regarding this issue:
1. Used the Query widget, and the point is recognized, and the associated popup works when I hover over the point in the results table.  I can even zoom into the point correctly.  A little limited on what you can write in the results table (no html?).  But all seems to work correctly using the query widget, and display results popup.
2.  Also used the search widget, I can draw a box around the spot I know contains the point on the map, but the results table puts the point back off the coast of Africa again.  Although it locates it correctly point wise, just not popup wise again.
I am pretty sure it is a bug with Flex, not my layer.  See attached image that has both widgets being used on these points.
[ATTACH=CONFIG]11935[/ATTACH]
