Popup info is adding many numbers behind decimal point?
9786
34
09-26-2012 11:37 AM
ReedDavis
I have configured my popup to show percent unemployment for the county that is clicked, the popup displays the information but adds about ten bogus numbers after the decimal on some counties. The source data is configured as follows: The percent unemployment field is float with precision of 6 scale of 2, number of decimal places 2. The same is occurring in the search tool which leads me to believe it is a source data formatting issue. Any Ideas?
StewartGalloway
Reed,
Did you ever come up with a solution to this?
Thank you.
Stew
[email protected]
ReedDavis
Stew,
No, unfortunately the project that I was working on was a temporary contract and the customer did not require this issue to be resolved. It still bothers when I check on the product; However no one is paying me to fix it so there it stays. Please post here if you find out any more...
RhettZufelt
MVP Notable Contributor
This is working just fine for me.
    <fields>
        <field name="Shape_Area" alias="Area of Feature" visible="true">
             <format precision="2" usethousandsseparator="true"/>
        </field>
    </fields>
Of course, if I set it to "-1" I get the default, which is a whole ton of zeros.
so, with it set to -1
     37,441.89976562478
Set to "2":
     37,441.90
R_
Works with my other numeric fields also.  Just figured everyone can come up with a Shape_Area field to test.
Though, I'm not using the description tag, so have not tested that part.
Ok, just tested using the description tag.  still working as expected.
RobertScheitlin__GISP
Yep,
   The original problem is very specific to a SINGLE (type) field it always worked fine with a double.
RhettZufelt
I thought he had tried changing it to double a few posts back, with no luck.  So thought it might be elsewhere.
R_
