Pop-ups only display at a large scale
3221
12-09-2013 08:52 AM
RobMiller
I am brand new to programming and ArcGIS Viewer for Flex, so I apologize if I am leaving out information or if this seems trivial.  I have added this map service to my application with the following properties:
<layer label="Wind Turbines" type="tiled" visible="flase" alpha="1.0"
         url="http://eerscmap.er.usgs.gov/arcgis/rest/services/wind/wTurbinesWM/MapServer">
     <sublayer id="1" popupconfig="popups/PopUp_WindTurbines.xml"/>
</layer>
My pop-up configuration file:
<?xml version="1.0" ?>
<configuration>
    <title>{SiteName}</title>
    <fields>
        <field name="image_name" visible="true"/>
        <field name="ORS_Number"  alias="ORS Number" visible="true"/>
        <field name="type_tower" alias="Tower Type" visible="true"/>
        <field name="lat_DD"   alias="Latitude" visible="true"/>
        <field name="lon_DD"  alias="Longitude" visible="true"/>
        <field name="image_year"  alias="Image Year" visible="true"/>
        <field name="blengthT"  alias="Length" visible="true"/>
        <field name="rotSwepT"  alias="Rotswept" visible="true"/>
        <field name="MW_float"  alias="MW-Decimal" visible="true"/>
        <field name="MW_text"  alias="MW-Text" visible="true"/>
        <field name="inst_year"  alias="Inst Year" visible="true"/>
        <field name="SiteName"  alias="Site Name"/>
        <field name="Bin"  visible="true"/>
        <field name="tothtT"  visible="true"/>
        <field name="confT"  visible="true"/>
        <field name="bl_float" visible="true"/>
        <field name="th_float" visible="true"/>
    </fields>
</configuration>
In my application, the pop-ups only display when I am zoomed in to a very large scale.  It would be much appreciated if someone could point me in the right direction on how to troubleshoot this issue.  I would like the pop-ups to display at all scales.  I am not even sure if this is an issue with my code for ArcGIS Viewer or with the map service.
Thanks for the help!
MichaelVolz
Esteemed Contributor
Is this a public URL whose REST endpoint I can browse to to see the properties of the mapservice?
Is this a mapservice showing windturbines as point locations?  Do you have a scale dependency set on the layer?
Can you see the wind turbines at a mapscale where you seem unable to get the pop-ups to appear?
RobMiller
I appreciate your effort, but I actually just figured it out and it turns out this was very trivial, so I apologize for the wasted thread.  This is a tiled mapservice and I simply had to set the popupconfig property for the remainder of my sublayers.
      <sublayer id="2" popupconfig="popups/PopUp_WindTurbines.xml"/>
      <sublayer id="3" popupconfig="popups/PopUp_WindTurbines.xml"/>
      <sublayer id="4" popupconfig="popups/PopUp_WindTurbines.xml"/>
      <sublayer id="5" popupconfig="popups/PopUp_WindTurbines.xml"/>
      <sublayer id="6" popupconfig="popups/PopUp_WindTurbines.xml"/>
</layer>
Thanks!
