Operational Layers are not loading.
3111
02-27-2014 10:48 PM
SunitSurati
I have made a web application through flex application builder but when i access the same web application on another system, it
throw's an error, and i have already set corssdomain.xml also at wwwroot, but then also i am facing the same problem.
[ATTACH=CONFIG]31857[/ATTACH]
Need Solution!
Thanks & Regards
Sunit Surati
RobertScheitlin__GISP
Sunit,
  Do you have the crossdomain.xml on the machine that is the ArcGIS Server, or are the web server and the ArcGIS Server the same machine?
by Anonymous User
Not applicable
Original User: sunitsurati
Dear Robert,
                 Yes i have crossdomain.xml on the server machine on which arcgis server is installed, then also it is not working.
Thanks & Regards
Sunit Surati
Sunit,
   Canyou acces the REST Service page from the other machine? i.e http://somemachine/arcgis/rest/services
