Opening OverviewMapWidget
1213
06-07-2012 07:20 AM
JamesEdge
Depending on the users selection within my widget I can zoom to various locations, scales, switch on/off layers etc. What I would like to do is to open the Overview Map as well. I am getting NaN for the widgetid so cannot open the widget in this way. I assume that is because it is defined in the UI section and not the main body of config.xml. Is it possible to open OverviewMapWidget from my widget?
RobertScheitlin__GISP
James,
   You can do it by following this forum post answer of mine:
http://forums.arcgis.com/threads/57718-Remove-a-UI-element?highlight=isController
Don't forget to click the Mark as answer check on this post and to click the top arrow (promote).
Follow the steps as shown in the below graphic:
James,
JamesEdge
Robert
as always, great support, many thanks.
