New Widget - User Configuration Selection Widget
711
08-06-2013 01:06 AM
AnthonyGiles
Honored Contributor
Flex Viewer Enthusiasts,
Please find a new widget that allows the user to select which configuration file load the viewer against:
http://www.arcgis.com/home/item.html?id=a28b758b3fc14c5794b30d5c230713fb
This widget is a cut down version of the widget found on ESRIs Public Safety COP Viewer:
http://www.arcgis.com/home/item.html?id=1d90b418b78e40158914bd5178b6892f
The standard config.xml is stripped down just to show the selection widget; the xml file for the widget specifies the images to use within the splash screen and which config files are associated to each image. Sample config files are supplied in the download.
Regards
Anthony
