Multiple Clustering
1212
04-15-2013 10:27 AM
LefterisKoumis
The clustering in the layer tag is a good way to deal with large amount of concentrated map points. However, if you wish to display the clustering symbols from 2 or more layers at the same time on the map, there is no way to differentiate the clustering symbols for which layer are for. Is there any way to include in the clustering symbol not only the numbers of points, but also the name of the layer that it is referring to? I know by clicking on the clustering you can get that info, but if you have several clustering breakouts it could a time consuming effort to identify the clustering of a specific layer.
AaronPerry
This may be over simplified, but you could have a unique clustersymbol for each layer, thus differentiating by the symbol itself rather than a text based identifier.
LefterisKoumis
Understood. However, if you have different symbols representing  different layers then you have to click each unique symbol to find the layer you are looking for. If I could use a custom png symbol, it would the problem without using text.
Thank you.
