Mouse cursor change over feature layer
2467
02-15-2013 04:04 AM
JanPacina
Greetings to all!
I have a point feature layer with defined pop-ups. Is it possible to change the default cursor (the little hand) to something else, when the cursor goes over the "active point"? There are only these points and tiled base map.
I am using the 2.5 version.
I have been searching the forum, but did not find anything to help.
Thank you in advance.
Jan
RhettZufelt
MVP Notable Contributor
I don't have 2.5 to test, but I believe putting this in the <map> tag should make it the standard pointer.  Though, should be the pointer all the time, not just on hover over point.
openhandcursorvisible="false"
R_
