Mini Map component
1347
04-18-2013 07:03 AM
ShaningYu
Honored Contributor
I plan to create a Mini-Map widget, which displays a feature queried.  Please hint me where I can get such a kind of component.  Thanks.
AnthonyGiles
Honored Contributor
Shaning,
Have a look at the overview map widget:
http://resources.arcgis.com/en/help/flex-viewer/concepts/index.html#/Overview_Map_widget/01m30000003...
If you change the line:
overviewMap.extent = map.extent.expand(3);
In the OverviewMapComponent.mxml
To:
overviewMap.extent = map.extent.expand(-3);
it will act as a magnifier instead
Regards
Anthony
AnthonyGiles
Honored Contributor
Shaning,
To:
Regards
Anthony
ShaningYu
Honored Contributor
I also considered to use the Overview component.  Let's me try if it works for my application.  Thanks.
