Saurabh,
I have updated by link in post 108 so that it links to the correct location in GeoNet.
Robert
Thanks a lot for the reply ![]()
Regards
Saurabh
Hi Forums,
One time i need to create simple login mechanism for flex viewer 3.6, i create it like this
<?xml version="1.0" encoding="utf-8"?>
<s:Application xmlns:fx="http://ns.adobe.com/mxml/2009"
xmlns:s="library://ns.adobe.com/flex/spark"
xmlns:viewer="com.esri.viewer.*"
xmlns:managers="com.esri.viewer.managers.*"
pageTitle="ArcGIS Viewer for Flex">
<fx:Style source="defaults.css"/>
<fx:Metadata>
[ResourceBundle("ViewerStrings")]
</fx:Metadata>
<fx:Script>
<![CDATA[
import mx.controls.Alert;
import mx.managers.PopUpManager;
protected function button1_clickHandler(event:MouseEvent):void
if(text1.text == "P4ssw0rd")
Alert.show("Login success!");
viewerContainer.visible= true;
else
Alert.show("Login failed!");
</fx:Script>
<fx:Declarations>
<!-- Place non-visual elements (e.g., services, value objects) here -->
</fx:Declarations>
<s:Form id="form1" x="3" y="1" width="226" height="64">
<s:TextInput id="text1" width="200" height="20" displayAsPassword="true" enabled="true"
prompt="Password"/>
<s:Button left="60" width="100" height="20" label="Enter" click="button1_clickHandler(event)"/>
</s:Form>
<viewer:ViewerContainer id="viewerContainer" visible="false" x="0" y="0">
<viewer:configManager>
<managers:ConfigManager id="configManager"/>
</viewer:configManager>
<viewer:dataManager>
<managers:DataManager id="dataManager"/>
</viewer:dataManager>
<viewer:mapManager>
<managers:MapManager id="mapManager"/>
</viewer:mapManager>
<viewer:uiManager>
<managers:UIManager id="uiManager"/>
</viewer:uiManager>
<viewer:widgetManager>
<managers:WidgetManager id="widgetManager"/>
</viewer:widgetManager>
</viewer:ViewerContainer>
</s:Application>
type 'P4ssw0rd' for password, and press enter
works fine for me,
Regards - Tommy
Hello everyone
I have applied the above code to get a login screen up and running
Thanks for this great work. But still i am searching how to load different config file according to role of the user
Thanks and regards
Saurabh
Saurabh,
The ability to have a certain config.xml based on the viewer that has logged in is part of the ArcGISSecurity web service found in this link:
https://community.esri.com/message/182812#182812
I am not sure which link you used to get your webservice for user validation but the one above uses a list of users names and passwords and the specific config to return once the user has successfully logged in.
Robert
I have used the different one . I will try with the one you have provided ( devsummit 2012).
Just wanted to know ..
Can We some how pass the Username to my Main app to show which user have logged in ..something like" Welcome Username" . I have seen that some one has posted the same query but i guess it was not answered .
Regards
Saurabh
Hello Robert
I have applied the code on IIS 8.5 ( gisbeta - /devsummit2012/ ). I got some error of duplicate records ( on line 14,16,17,18,19 of web.config) which i commented ( as i did in previous code ) . After that i got directory browsing error which i resolved again. But now im getting this error. I have changed the line of username and password which u have mentioned earlier .
thanks and regards
Saurabh
Saurabh,
Here is a VS2013 version that uses .NET 4.5.1 (since you are one windows 8). You will need to change the wsdl url in the index.html from
ws.wsdl ="http://yourserver/ArcGIS_Security/Service.wsdl";
to
ws.wsdl ="http://yourserver/ArcGIS_Security/ValidateUser.svc?wsdl";
As far as your question about returning the logged in user name. That is done in the Flex Viewer Files\src\index.html included in the zip file I linked in the previous post.
Robert
I will try to integrate this one and will post the result accordingly
Thanks and Regards
Saurabh
Robert
The service works fine but its not uploading different config file!! Am i missing something ?
I can see that service is returning the config file name from the xml but cant see any piece of code that uses the output config file except this one:
if(configFile != ""){
var outArray:Array = configFile.split(",");
usrConfigfile = outArray[0];
I am not able to get how to use this to load the specific config file
regards
Saurabh
