Legend Widget Text Formatting
933
07-27-2011 10:34 PM
IanHamilton1
I have put return characters in the text I want displayed in the Legend Widget to create multiple lines. This has worked to a certain extent. The text however is centre justified. Would it not be better to have this left justified?
Is there a way of changing this by some hidden config entry?
RobertScheitlin__GISP
Ian,
   Nope, if you look at the legend source code that is nothing to it because all the work is done internally in the API's Legend component. You can extend the LegendSkin.mxml of the API and fix it though.
