LayerList widget positioning
2407
02-15-2011 05:40 AM
K_Rocks
Hi all,
I have seen discussion on a bug to do with widget positioning within the float widget container, but the problem I'm having is with LayerList, which is in the UI Elements section of the config file and given an initial position close to the top right of the viewer.
On opening the viewer, a splash screen appears, and the LayerList is in the correct place, but the list jumps across slightly towards the centre of the viewer when the splash screen is closed and again when a new widget is opened. On trying to move it back it is blocked, as there seems to be a line which the list cannot be moved past to the right, even though there is no limit to moving it up, down or left.
Has anybody else come across this before? We're using the 2.2 pre-compiled Flexviewer.
Thanks for any help.
