Issues with 3.1 Flex Viewer and App Builder
6923
20
12-18-2012 09:54 AM
JoshWhite
Honored Contributor
I pulled these posts from another thread. The original posts are at http://forums.arcgis.com/threads/73572-ArcGIS-Viewer-3.1-for-Flex-released-December-13-2012?p=257627...
Yesterday 09:29 AM#2
Re: ArcGIS Viewer 3.1 for Flex released December 13, 2012
I cannot figure out what is going on. I downloaded the compiled version and the app builder for 3.1. I upgraded a test application and checked my layers. I tried to open the app in IE and while I don't get any errors, all I get is the clock symbol spinning. I also noticed that I couldn't edit the Attribute table widget in the Layout tab. In the preview tab, I get the spinning clock symbol and a bar across the screen, I assume the attribute table, when a broken image icon in the middle. Help what is going on?
Also when I click on Map Extent under the Maps tab, the application builder becomes unresponsive other than the fact that when I close it asks if I want to save any changes.
Josh White, AICP
Principal Planner
City of Arkansas City
KimBülow
Thanks Bjorn, it help, but no Basemaps, i look forward to 3.2 Because, we like atribut container, but  we do not compiling the source ourself.
-- from http://resources.arcgis.com/en/help/flex-viewer/concepts/index.html#//01m300000011000000#GUID-82B3FE...
Kim,
It's correct that you have to set those two parameters, do you still have problems after doing that?
As for other solutions:
If you are compiling the source yourself, the code is available on GitHub to work around this.
Or you can wait for the next release, version 3.2, which among other things will add supports for 6 new locales, including Danish. We're planning to release 3.2 at the end of March.
Or you can use the previous (3.0) version.
