Is it possible to re-size a list (increase/decrease) in proportion to widget pane?
2228
04-04-2014 01:32 PM
by Anonymous User
Not applicable
Original User: 95vtec
Hello all,
Before I try to explain what I am asking here...it may be eastier to take a look at the 2 pictures (a before and after) that I've attached.
I'm basically trying to figure out why the list (in this case a list of layers) is not expanding with the widget panel when I re-size the pane.  When the layer names are past a certain length, they get cut off.  I'm basically trying to expand the widget panel so that the list expands with it.  I can attach code or whatever is needed.
Jesse
by Anonymous User
Not applicable
Original User: rscheitlin
Jesse,
   As this is a custom widget (which looks like one you obtained from Larry in Hamilton County), it is more of a question for the widget developer. The widget is working as designed by that developer and was likely never coded to resize with the widget template.
Second widget questions belong in the ArcGIS Viewer for Flex forum not in the Flex API forum (I have moved it to the appropriate forum).
JesseHopkins
Robert,
Thanks for the quick response.  Yeah that is Larry Stout's custom "Simple Identify" widget from Hamilton County, Indiana (I just wasn't sure if it was a Flex Viewer issue or cusom widget issue).  I'll go ahead and bother him and see if he has any suggestions.  Thanks again.
Jesse Hopkins
