�??Invalid settings�?� when starting the �??ArcGIS viewer for flex�?�,
4385
6
12-20-2012 07:53 AM
JamalNUMAN
Legendary Contributor
Please, have a look on the screenshots below
[ATTACH=CONFIG]20106[/ATTACH], [ATTACH=CONFIG]20107[/ATTACH]
I there any reason behind getting the message �??Invalid settings�?� as I started the �??ArcGIS viewer for flex�?�?
Thank you for the help,
Best
Jamal
Jamal Numan
by Anonymous User
Not applicable
Original User: [email protected]
Jamal,
Is your IIS working correctly?
If you put in http://localhost/ (on your server machine) or http://yourserver.name/ in your browser, what do you get?
Regards
Anthony
JamalNUMAN
Jamal,
Regards
Anthony
Thank you Anthony for the answer.
i got the messages in the screenshot below:
[ATTACH=CONFIG]20121[/ATTACH], [ATTACH=CONFIG]20122[/ATTACH]
best
Jamal
Jamal Numan
by Anonymous User
Not applicable
Original User: mattias_j
Do you have write-acces to C:\inetpub\wwwroot\?
See the "Security settings" part here: http://resources.arcgis.com/en/help/flex-viewer/concepts/index.html#/Installation_guide/01m30000002w...
AnthonyGiles
Honored Contributor
Jamal,
The fact you are getting the page cannot be displayed window would suggest that IIS is not running on your local host
Regards
Anthony
by Anonymous User
Not applicable
Original User: hgonzago
One other thing you can try to just verify it's not something that may be left over from a previous install is to go in and remove the C:\Users\{username}\AppData\Roaming\com.esri.ags.AppBuilder3.0 folder.
There is a step for uninstalling App Builder that talks about this. You can find it at http://resources.arcgis.com/en/help/flex-viewer/concepts/index.html#/Installation_guide/01m30000002w....
If this still doesn't work, I would go with what the previous poster stated regarding making sure you can access your IIS web server via localhost.
JamalNUMAN
Thank you Mattias, Anthony and Heather for the answer. Your contribution is quite useful.
I installed the IIS and adjusted �??user account control settings�?� and it did work.
[ATTACH=CONFIG]20146[/ATTACH], [ATTACH=CONFIG]20147[/ATTACH]
Best
Jamal
Jamal Numan
