Intersection Search in Flexviewer
1086
5
04-13-2011 05:15 AM
NasifAlshaier
Hi..
is there a way to do a search for an Intersection in Flexviewer?
I tried to use the current search in Flexviewer and it did not work.
Thanks in advance
EricVenden
I've configured an intersection/address search.  You need to publish a geocoding service.  Use this geocoding service as the source in the Locate widget.  You can set the intersection identifier when you set up the geocoder in ArcCatalog (such as Main@First or Main\First).  You will have to use this in the Locate widget.
Hope this helps.
Eric
NasifAlshaier
Thank Eric.
I am using the geocoding service from arcgisonline,... the ones came with Flexviewer..
EricVenden
Yeah..I just tested the "default" locate widget with the supplied ESRI services....intersections work by specifying the @ or & symbols in between the 2 streets....
Eric
NasifAlshaier
Hi Eric.
I do not if I am missing something in the code... I tried @ and & for the following intersection and it did not work..
the intersection is : sw 8th st & sw 4th ave
City:                     miami
thanks
EricVenden
Not sure what to tell you..I have found that the geocoder I set up is pretty sensitive and you need to be right on with the streets.  I have taken this widget out of my app for now.  I need to look at the geocoding service and see if I can "open" this up a bit.
Eric
