Insert code into index.html
3555
02-27-2012 03:50 PM
IsaiahAguilera
I would like to use a favicon for my flexviewer. Currently I export release build and then go into the index.html and add the line of code that makes the favicon work. Is there an easy way to just add this into flash builder somehow so when I export release build it enters the line of code for me and saves me a step. Any help is always appreciated.
Thank You,
RobertScheitlin__GISP
Isaiah,
   All you need to do is add the favicon line to the FlexViewer2.5/html-template/index.template.html.
I did see your other post but need to ask you to always start a new thread after the first question is answered.
IsaiahAguilera
Never mind after some combing through the forums I saw that Robert had already answered this.
http://forums.arcgis.com/threads/22321-Flex-2.2-Favicon?highlight=favicon
Isaiah,
IsaiahAguilera
Will do, thanks Robert!
