Initial extent does not work anytime
1633
08-10-2012 12:38 AM
MagalyC_
I have a problem that appears sometimes when the application is loaded.
You can see on picture 1 than my initial extent is not loaded as it should.
In the picture 2 you can see the normal display, I just reload the application...
I don't understand... 😕
Thanks for your help!
by Anonymous User
Not applicable
Original User: philipp37
Are you by any chance using the login code from here http://forums.arcgis.com/threads/25899-Login-Screen-for-the-Flexviewer?highlight=login+zooms
...if so, read about half way down on the first page of that thread, I had the same issue.  Robert Sheitlin updated the code to fix the problem (his updated code is also in the same thread I believe).
by Anonymous User
Not applicable
MagalyC_
Thanks a lot, I have forgotten this issue and I certainly remove the portions of code in the ViewerContainer.mxml with an update.... 😕
