Identify Widget target features are shifted
1437
03-22-2013 10:28 AM
NinaRihn
When I identify features with the Identify widget, I have to click up and to the left of the feature I am identifying if I use the point, and when the identified feature highlights on the map, you can see that it is shifted up and to the left.  I just tell people to use the rectangle tool instead of the point because it is hard to grab a point feature with a single click, but this shouldn't happen.  Any ideas why it might be?    A sample of is attached.  the pink is the area I clicked on, and the blue is the actual result polygon.
Otherwise the tool works fine.
RobertScheitlin__GISP
Nina,
  I have never seen this. Is you data and your basemaps the same WKID? Are you using some unsual projection? What version of ArcGIS Server and SP are you using?
Nina,
NinaRihn
thanks for your response... After you mentioned projections I thought to go and check my MXDs and sure enough, I forgot to send the HARN to WGS84 transformation in the on-the-fly projection to WMAS.. I fixed that and it fixed the problem.
