Identify Widget Number Formatting Issue
1410
04-25-2012 09:35 AM
LixinHuang
Robert,
While I was using your Identify Widget (2.5.5), it seemed to me that the number with Float type can only be displayed as integer number. However, the number with Double type can be displayed as decimal number. I tried to set  "numberformat" option for the "Field" tag as I did for your Enhanced Search Widget. It seemed to me that it did not work for Identify Widget. Is there any way to format the nmber with Float or Double types? Any helps or suggestions would be greatly appreciated.
RobertScheitlin__GISP
Lixin,
I put out a new version 2.5.6 this evening that should fix your issue.
Don't forget to click the top arrow (promote).
Lixin,
   What works in one of my widgets is not gaurenteed to work in another. It would have to be listed in the documentation for that widget.
That being said I think that this is a good enhancement and it has been added to the enhancement list for the Identify Widget.
LixinHuang
Thanks Robert. I am looking forward to your next release of Idenify widget.
Lixin,
LixinHuang
My issue was solved by your Idenftiy Widget 2.5.6. Thanks for your hard work and wonderful widget.
